looking for right type of bearings
Old Aug 24, 2017 | 11:39 AM
mperezh's Avatar
Default looking for right type of bearings
I have a F20b engine that I am putting a f23 crank what size of bearings do I need ?
Old Aug 24, 2017 | 04:28 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: looking for right type of bearings
If you are installing the F23 rotating assembly into the F20 block, then just use F23 bearings.
IIRC the only differences were between rod journal diameters, but this is a non issues as the blocks(besides bores) are pretty much the same. Check the FAQ at the top of the page as there is a H/F engine break down info.
Old Aug 24, 2017 | 07:44 PM
mperezh's Avatar
That's what I thought so f23 main and rod bearing would work out right ?
what would you guys recommend getting the bearings from Honda or any good after market brand that's trusted ?
Charlie Moua
Jan 16, 2012 07:01 PM
omglook89
Jul 14, 2011 08:49 PM
ek_civic96
Oct 24, 2008 05:40 AM
JeremyL
Jan 6, 2003 01:59 PM
TheSwift1
Nov 12, 2002 08:12 AM
