98 integra won't start
Old Aug 24, 2017 | 07:45 AM
CorbenM's Avatar
Default 98 integra won't start
Hi,
The problem:
I've got a manual 1998 integra GS that stalled on me while leaving a parking lot, now it won't start. The car engine cranks but won't start. When I press on the gas while cranking, the engine shakes more but still won't start, not even a little.
What I've done:
- Replaced the distributor assembly(not just the cap)
- Removed the air cleaner(temporarily)
- Plugged in a code reader that "failed to establish connection" every time
- Soldered cracked joints on the main relay
- Checked continuity on both ends of the fuel pump connector(Fuel pump side has continuity, relay side doesn't, even when key is turned)
- Checked fuses
- Battery voltage is 12.3v
Any help or suggestions on what to try would be much appreciated, thanks
Old Aug 24, 2017 | 08:08 AM
mechman_22's Avatar
Default Re: 98 integra won't start
you check to make sure your getting spark? you make sure your timing belt didn't break?
Old Aug 24, 2017 | 08:34 AM
CorbenM's Avatar
When I get home I'm going to pull one of the spark plugs and test if there is spark now, tow truck driver said there wasn't before. The timing belt is another thing I checked, forgot to put it in the post
Old Aug 24, 2017 | 04:31 PM
tamboo's Avatar
10 Year Member
use an hei spark tester so you dont fry the coil. cheap as chips.
Lisle 50850 Ignition Spark Tester
Old Aug 24, 2017 | 05:01 PM
CorbenM's Avatar
Update: Tested the fuel pump with a battery, and it works. When I plugged it back in and turned the key it wouldn't work. I also tested for spark and still wasn't getting any. This now brought my attention to the ECU. Checked the fuse for it and sure enough it was blown, I had only checked the fuses under the dash. So I changed the fuse, the car started up but after a few seconds it died again. Checked the same fuse and it was blown again.
Old Aug 24, 2017 | 11:41 PM
CorbenM's Avatar
Update: Found and solved the problem, wires from front O2 sensor were getting caught in the axle. The wires kept shorting out whenever the car would move. When the wires shorted out it blew the fuse for the ECU which caused no spark and the fuel pump not working. Zap strapped the wires out of the way and the car worked just fine
Turbo2374
Apr 23, 2013 08:33 PM
graycivic
Mar 2, 2013 08:15 AM
heeltoehonda
Dec 5, 2009 11:39 AM
szczerbanator
Jun 26, 2009 09:07 AM
Tr0LL
Sep 24, 2008 04:40 AM
