Wiring a odb1 vtec to odb2a P2E ecu
Old Aug 24, 2017 | 04:28 AM
Chris Barbrow's Avatar
Default Wiring a odb1 vtec to odb2a P2E ecu
Still a bit of a noob on motor swaps, but just put a mini me (y7 block/z6 head) in my 98 civic LS (nonvtec). Have almost everything hooked up except my vtec solenoid. Cant seem to find anything about wiring it up tp a stock 98 odb2a (p2e) ecu. Can i follow the normal diagram for odb2a ecu and hook my vtec up or do i have to get the p28 ecu and harness adapter?
Old Aug 24, 2017 | 07:33 AM
mk378's Avatar
Default Re: Wiring a odb1 vtec to odb2a P2E ecu
Assuming it is a manual car.
To stay OBDII and have VTEC, you need to swap in a manual EX ECU. That system uses a different IACV than the manual LX. So you have to swap to a manual EX intake to replace your 3-wire IACV with a 2-wire one, and rewire the IACV circuit.
To use an OBD1 ECU you also have to convert to 2-wire IACV, as all OBD1s are two wire.
Old Aug 24, 2017 | 10:22 AM
tony_2018's Avatar
Fish Twig
p2e does not have vtec
Old Aug 25, 2017 | 03:32 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-...-vtec-2987229/
Kamilsamek
Jul 25, 2018 05:58 AM
jdmh22:)
11
Feb 18, 2012 08:05 PM
sony224422
Mar 1, 2007 02:16 PM
zx2gotboost
Mar 11, 2006 05:27 PM
MM's94Civic
Jun 30, 2004 08:59 PM
