transmission problem
Old Aug 24, 2017 | 03:16 AM
mano69's Avatar
Default transmission problem
hi i have a 97 150i honda civic mileage 155000kms, my manual gearbox when under load it make a winding sound, it started out only on first and 2nd gear but now it seems to be doing that until firth, what can it be and how can i stop this?
Old Aug 24, 2017 | 06:28 AM
2x0's Avatar
2x0
10 Year Member
Default Re: transmission problem
I would start by replacing the fluid.
Old Aug 24, 2017 | 07:29 AM
mk378's Avatar
Yes, or at least take the fill plug out and check that it is full.
If fluid is full, and you hear a substantial whirring / grinding noise while idling in neutral that goes away when you press the clutch down, the input shaft bearings are probably bad.
Murilo EJ1
Transmission & Drivetrain
Jan 16, 2019 12:30 PM
Mckinney88
May 12, 2014 01:18 PM
civicheaven89
Aug 14, 2013 03:05 PM
SpeedoKing
16
Dec 21, 2007 12:48 PM
globy123
Dec 25, 2006 09:24 AM
