Suspension & Brakes Theory, alignment, spring rates....
93 Civic Hb with Koni/GC issue running 235/50/15
Old Aug 23, 2017 | 09:27 AM
gutted-dx's Avatar
Icon4 93 Civic Hb with Koni/GC issue running 235/50/15
My setup is what the title states and I'm having issues with not being able to lift the car up high enough. My problem is the driver side has 5-6 threads left to lift the car up with still and the passenger side is maxed out. My questions are, is the sleeve directional could I have it upside down? The threaded sleeves in the rear are longer, should they be up front? Its so close! I'm looking for someone that has recently done the install or have a set they can take some pics of.
Thanks,
Joe
Old Aug 23, 2017 | 12:33 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 93 Civic Hb with Koni/GC issue running 235/50/15
Collars only go one way
Buy longer springs, perhaps.
Old Aug 24, 2017 | 02:19 AM
NVturbo's Avatar
O.G. triple O.G.
^^^ these are the older model coilovers. If I'm not mistaken, the newer ones have a solid (non-threaded) section on the lower portion for the rear sleeves. You sure the shocks are still good and aren't leaking??
Old Aug 24, 2017 | 06:46 AM
egsleepercivic's Avatar
what ring on the shock are the c lips on?
I believe the fronts have 2 spots, stock height and -1in
The rears have 3 spots +1in , stock, -1in
Also what length springs do you have ? if you don't know post the #'s on the springs
Old Aug 24, 2017 | 09:36 AM
B serious's Avatar
I think he's doing this for some sort of offroad build. So he's trying to get a ton of height. If he doesn't want to change spring rates, he just needs longer springs or spacers.
What would leaky shocks affect in this case?
Old Aug 24, 2017 | 12:16 PM
Tyson's Avatar
this.
Old Aug 25, 2017 | 02:07 AM
NVturbo's Avatar
O.G. triple O.G.
unevenness of the car
Old Aug 25, 2017 | 04:01 AM
B serious's Avatar
A leaking shock condition doesn't affect height. Especially twin tube shocks.
Unless you meant something else?
BiG ChOr!Zo
Suspension & Brakes
13
Mar 25, 2011 05:25 PM
ware
Suspension & Brakes
20
Aug 9, 2008 04:37 PM
daily
Suspension & Brakes
Mar 21, 2006 09:51 PM
ftwlucky13
Suspension & Brakes
21
Apr 5, 2005 01:13 PM
Jdm93civic
Oct 13, 2003 05:32 PM
