Suspension Play
Old Aug 23, 2017 | 01:28 AM
zakl's Avatar
Default Suspension Play
Hi there, I have a problem with my EK when I accelerate from a dead stop there is a play on the suspension. The mountings are not broken. I have changed the steering rack, checked ball joints, tierod ends. I put the front wheels on jack stands then put the car in gear and played with the clutch to recreate the problem it looks like the play is on the shaft going into the tranny. Can this be the case? If for example I am at a stop and without even using the accelerator paddle I release the clutch there is a play if this makes sense.
Old Aug 23, 2017 | 02:12 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Suspension Play
bad shocks
Old Aug 23, 2017 | 03:58 AM
zakl's Avatar
I have brand new shocks
Old Aug 23, 2017 | 05:12 AM
civic402lx's Avatar
Get an alignment check
Old Aug 23, 2017 | 06:29 AM
zakl's Avatar
I will get that done when I get a chance and see
Old Aug 23, 2017 | 06:30 AM
zakl's Avatar
guys any chance the shaft could be causing this?
Old Aug 23, 2017 | 06:58 AM
theYBLEGAL's Avatar
Loved
I'm having the exact same problem right now too. I have all poly lca bushings, good ball joints, new upper A arms, new tie rod ends and even a new driver side axel.
​​​​​​You may have worn out your CV joints on your axels tho.
Old Aug 23, 2017 | 07:04 AM
civic402lx's Avatar
You need to get an alignment done anytime you work on inner or outer tie rod. When i bought my civic, the steering and front end feel loose. After alignment, everything tighten up and back in spec. No more loose feeling. Working on suspension, i would suggest the same. Get it check, im sure it is out of spec.
Old Aug 23, 2017 | 07:08 AM
theYBLEGAL's Avatar
Loved
For me, it's super straight. I do my own alignments. 5000 miles later, no visible tire wear.
From a dead stop, having suspension play, should have nothing to do with needing an alignment other than premature failure of bushings and things. But if you are inspecting things, and they check out, then you are beyond that anyway
Old Aug 23, 2017 | 11:23 AM
zakl's Avatar
I would think that having the car in the air on jack stands has nothing to do with alignment and bushings because there is no strain now on any of those components. I had someone release the clutch with a quick motion to recreate the issue and I was underneath it looked to me as if the tranny shaft was causing this. I am no professional I am here for advice but I also know enough to connect the dots.
Old Aug 23, 2017 | 02:00 PM
theYBLEGAL's Avatar
Loved
Sounds like the inner CV joint tho. Use muscles.
Old Aug 23, 2017 | 08:43 PM
zakl's Avatar
What do you mean use muscles? How do I make sure it is that?
Old Nov 20, 2017 | 11:41 PM
zakl's Avatar
Did you solve your problem? I have changed driver shaft axle with new inner and outer cvs and still have play when accelerating. The play is very annoying especially in traffic. I would really like to solve this I have double checked mountings, tie rod ends and ball joints.
Old Nov 21, 2017 | 05:17 PM
theYBLEGAL's Avatar
Loved
Yeah, it was the steering rack that was bad. I think untorquing and retorquing the new inner tie rod ends on helps make the rack fail faster. My rack wasn't that bad till I changed the inner and outer tie rod ends.
So my new recommendation is to not change the inner tie rod ends ever. If they need changed, change the whole rack. If you now find that it is indeed your rack, you will be bummed to find out further that a new reman rack comes with new inner tie rod ends. (there is probably a reason...)
Old Nov 21, 2017 | 10:09 PM
zakl's Avatar
I have also changed my rack there is absolutely no play on my wheels so now I dont know.
Old Nov 22, 2017 | 01:35 PM
theYBLEGAL's Avatar
Loved
Do you have an aftermarket wheel? If so, does it have a quality mount?
Check every component. Break it down into sections. Start at the wheel. Verify there is no play between wheel and column shaft. Verify there is no play between column shaft and pinion of the rack.
Let us know!
Old Nov 24, 2017 | 04:29 AM
zakl's Avatar
I have the oem Vtec wheels, there isnt any play on the wheels when its jacked up I have checked that. There used to be a play before I changed the rack and shaft.
Old Nov 27, 2017 | 10:27 PM
zakl's Avatar
I think I might of found the problem...the front right mount is a bit worn not much though I will see if I can get it swopped this weekend, I am just thinking would this mount cause that significant amount of play so I am hoping its this because its driving me nuts.
arziffel
Jan 31, 2012 07:36 PM
Tysnet
Jun 7, 2008 01:50 AM
jdmh22luda
Jun 26, 2007 12:44 PM
mr2man
Apr 25, 2007 09:42 AM
jerbear!
Suspension & Brakes
Feb 9, 2005 04:10 AM
