clutch kit
Old Aug 22, 2017 | 11:27 PM
101990's Avatar
Default clutch kit
honda ballade(luxline) 180i/ 98model/ is there a specific clutch kit for my honda coz i heard u get different models for 180i ill prefer a luk clutch
Old Aug 23, 2017 | 05:48 AM
egsleepercivic's Avatar
Default Re: clutch kit
What motor does it have, can you take a picture? it looks like it is the same as a civic here in the US
Old Aug 24, 2017 | 08:48 AM
thewrai6th's Avatar
I believe that is a D16Y9. Any D series clutch should work. This should be in the 96-00 Civic forum.
Old Sep 1, 2017 | 11:37 PM
trm4life's Avatar
Personally I HIGHLY recommend going with exedy, they make the OEM clutch for Honda and many others. That said there are kits that sell exedy clutches with LUK fly wheels. If you're running stock, or close to, an organic OEM clutch will work just fine. It will also be more durable than XTD and other cheap crappy clutches. Running a stage 1,2, or 3 clutch isn't necessary. If you use the original flywheel, you MUST get it "turned" or resurfaced. A lightweight flywheel, will give you instant power without needing any upgrades or a tuned ECU. Again, DON'T GO CHEAP.
Old Sep 2, 2017 | 08:31 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Exedy OE replacements are the only inexpensive OE replacement clutch I would use. Seems like the other brands suck....and are more expensive
fiitzy
Transmission & Drivetrain
Mar 14, 2013 11:49 AM
jwhezzy2003
Aug 28, 2008 08:46 AM
cbmprelude
11
Apr 27, 2006 08:39 AM
WTR
Jul 12, 2005 10:35 PM
