water mixing with oil
Old Aug 22, 2017 | 03:31 PM
j.rios8834's Avatar
Default water mixing with oil
2000 honda accord 2.3l ulev vtec
having problems with coolant mixing with the oil mostly in the valve cover, obviously first thing to do is change head gasket, and Ive done that, didnt take care of the problem. Change the head from a junk yard car, also sent to machine shop, pressure tested, surfaced, and new valve seals installed, along with another new head gasket,exhaust, and intake gaskets. could there be anything else other than a cracked block? also this is my first honda. any help would be appreciated. thanks in advance.
diesel mechanic for 10 years
Old Aug 22, 2017 | 11:44 PM
holmesnmanny's Avatar
Default Re: water mixing with oil
What were your original compression test numbers ? What are the current compression test numbers ? Have you tried pressurizing the radiator and seeing if the block is leaking internally ? If there are no external cooling system leaks then there is likely a crack in the block.
jerry lar
Jun 11, 2014 05:50 AM
keith1993may
12
Jul 10, 2013 04:18 PM
rice a roni
May 31, 2006 07:18 PM
TGUNNER
May 26, 2004 11:10 AM
