(MD) WTB: Misc EK 'upgrades'
I have a '99 Civic DX Hatch with a B20B swap. I'm looking for some upgrade parts, below is a list of some of the things I am looking for. If you have anything that might interest me, shoot me a message.
I'm actively looking for:
- Rear Sway Bar & Rear Subframe Brace
- Cruise Control parts (for manual trans); gas pedal, under dash wiring, engine control unit, etc piece parts.
- Electric Windows (Doors) with wiring harness and control modules
- GSR VTEC head parts
- Header with 2.5" collector (Toda style)
- Spoon intake elbow or Mugen Air Intake box (for EK9)
I am located in Southern MD, but travel up towards DC/Baltimore often.
9/14/2017 BUMP; I am looking for some Front Suspension Parts:
- Lower Control Arms with Sway Bar mounts. If they are the SI (stamped steel), I'll need the Strut forks as well.
- Sway Bar with end links to match LCA.
- Energy Suspension poly bushings (more the better)
Anyone have any parts laying around before I go Junkyard hunting?
Tell me your price; I am located in Southern MD, but travel up to Laurel often. IF shipping is involved; give me the final cost of purchase with payment from PayPal.
9/19/2017 Update... I was able to pick up most of the suspension parts that I needed. However, I'm still looking for:
- Random suspension bushings from Hardrace, Energy Suspension, and/or Prothane
- "EK" Sway End Links (with bushings)
- Arm Rest/Center Console with mounting bracket (in the gray/charcoal/black color)
UPDATE 2/7/2018... My long term list of items that I am looking for has been updated in the orginal post.
I would like to begin locating all the parts for Cruise Control and Electric Windows.
- Thanks, I have one now.
- Right now, this is lower on my list of things to buy. I'll focus on looking for on in the Sumer time, once I still the B16 head on.
- No thanks, the Non-TypeR calipers should be plenty enough for my needs.
I have the under dash wiring harness, ecu and what misc parts are you needing?
I have the electric window and door lock floor harness.
Everything has been removed and uncut unless noted.
5/15/2018 - Update: I am currently gathering parts for my B20 - VTEC (GSR) head swap
I currently have:
GSR head (ported & polished) with VTEC solenoid and Dizzy
Supertech Valve, Dual Value Springs and Retainers
Type R cams with Skunk2 cam gears
Skunk2 Pro intake manifold
Thermal Intake
Golden Eagle Head Studs
Oil Sandwich plate & alignment dowels
I am looking for:
- Type-R throttle body (62mm) (Maybe interested in a 65/66 TB)
- VTEC wiring sub harness
- Dizzy OBD2 adapter: OBD2b (Small 8 pin; SOHC) to OBD2 (Large 10 pin, OBD2a & Integra)
- TODA rep/style Header (will look at other 2.5" collector headers).
- 84-84.5MM head gasket
- GSR top end gasket kit
I currently have:
Thermal Intake
I am looking for:
Well, unfortunately I was involved in an accident and I am no longer building on the Civic. The other driver tried cutting across 3 lanes on the DC Beltway to make an Exit and I "t-boned" him. After the accident I picked up a nice, clean, tastefully mod'd '95 Integra GSR and I am going to be moving some parts from he Civc over the Integra and then parting out/selling the rest of the Civic parts.
In order to keep track of what parts are available, I create a Google Sheet: https://docs.google.com/spreadsheets...it?usp=sharing
HypeR0070
Jun 30, 2004 04:48 PM
