Front EK lca/sway SI question with control fork?
This seems like a really really stupid question. I'm just retarded today. Cann't think straight. The car I'm working with/on is a 99 Civic DX Hatchback.
I've been ordering parts, and have been looking for parts. However I know that to add the front sway bar from an Si that the following parts are needed.(along with the necessary brackets/bushings/bolts/etc.)
I am ready to purchase the following99-00 Civic Si parts)
Front sway bar
front lower control arms
damper forks
My question is, I already purchased, and have a set of Tein Flex coilovers waiting to be installed. Now I haven't seen it yet, because I haven't gone to pick it up and i'm not thinking straight today.... ughh. In any case, i'm pretty sure i DO NOT need to order those damper forks. Am I correct? Since I got the coilovers, i don't still need the dampening forks? eh, confused...
So am I correct that all i need is:
front sway bar
I do not need the damper fork right? Thanks guys, Im just not on today. Or Do i need these damper forks? ughh.. i'm confused, I think I need them? egh...mebe ill just order them anyway....
Modified by HypeR0070 at 5:45 PM 6/30/2004
Front sway bar
damper forks
front sway bar
Re: Front EK lca/sway SI question with control fork? (HypeR0070)
Yes, you need them. However you could also use EX LCAs, ITR endlinks and keep the DX shock forks if on a budget. However the SI front end links are a better setup IMO. However if using SI lower arms, you have to use the si forks as well.
Re: Front EK lca/sway SI question with control fork? (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote"> However you could also use EX LCAs, ITR endlinks and keep the DX shock forks if on a budget. </TD></TR></TABLE>
not if you want to use an si front sway. si front sway must have si lca & si forks, unless you buy mr choi's endlinks.
Re: Front EK lca/sway SI question with control fork? (ruthless013)
Bump...just the thread I needed. I'm going to be installing the Si front sway bar.
Sorry to hijack your thread, but do you guys know where to mount the sway bar too? Do I need any extra hardware? Are the holes already supplied?
Re: Front EK lca/sway SI question with control fork? (2000DX)
holes should all be there in the subframe. subframes aren't different between the civics.
need brackets and bushings.
RR98ITR
10-08-2009 10:07 AM
louie3252
08-31-2006 05:36 PM
louie3252
05-15-2006 10:01 AM
