1994 del sol s 1.5 quick mount struts
Monroe sells a quick mount strut, part number 171946 and 171945...
Monroe's website said they don't fit but a few other sites and NAPA said they fit...
Has anyone used them and, if so, what was the outcome?
Thank you
Thank you
the physical fit is not the issue, it is the spring rate and load that may vary on the OE springs of a del sol vs a civic. Personally I would use them without hesitation as the difference is likely minor and probably a little softer for the civic than what the del sol had.
wzakaras
Nov 13, 2013 08:54 AM
JDMeg2si
Dec 24, 2009 04:56 PM
