2004 Honda Civic No Start No Crank
My 04 Honda Civic has twice done this. I press in the clutch turn the key and get the dash flickering. I got the car started once by taking the battery off and putting it back on.
I recently did an oil change on it as well as I thought it would help but guess it didn't.
So this morning I pressed in the clutch and turned the key and just lights on the dash. No start No Crank. I tried the battery again but nothing worked.
I'm just wondering if you guys could help me out by listing things that may be the problem and possibly providing some solution. Please and thank you I'm trying to make this car last
Possibly bad battery, starter, or bad ground. Have the battery and starter tested first to rule them out. Check your battery connections are clean and not corroded, as well as the engine and tranny ground cables.
If those are good, next things to check would be clutch safety switch, relays, and ignition switch.
Good luck
Good luck
Good luck.
ED6
Apr 30, 2004 05:32 AM
