Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 EX Automatic - Park won't start Car
Old Aug 15, 2017 | 12:17 PM
Tony CR's Avatar
Default 2006 EX Automatic - Park won't start Car
Hi everyone,
im stuck with this one. My civic sometimes don't start even though the automatic shifter is on P and the brake is pressed and the key is turned. What I can do is while the car is off and the brake is pressed, I will shift to D then back to P and then turn the key and the car will start. There is no issues with shifting and no really sounds with the transmission. I am guessing there is electronic issue that is failing. What can I try to check to make sure I'm not stuck with a dead car because of an electrical issue?
Old Aug 16, 2017 | 03:05 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: 2006 EX Automatic - Park won't start Car
Why do you feel the need to press the brake when turning the car on when its on park?
Old Aug 17, 2017 | 08:57 AM
nsxmatt's Avatar
When it's not starting see if the light on the dash shows it in park. If not then it may the range switch on the transmission not switching it back to park.
Old Aug 20, 2017 | 08:18 AM
97emsedan's Avatar
correct...
SirCharles1985
Honda Civic (2001 - 2005)
Oct 23, 2012 04:37 PM
civicflow
Feb 25, 2011 05:38 AM
dj-t
Jan 3, 2011 04:38 PM
RutRow
Jan 23, 2009 02:01 PM
funkify
Jun 30, 2004 11:33 AM
