Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Clutch master cylinder.
Old Aug 13, 2017 | 06:19 PM
prodjay10's Avatar
Default Clutch master cylinder.
The clutch pedal stared acting weird. It wouldn't return all the way up and kept getting lower.
I tried to bleed. That didn't help. I assumed that it was the clutch master so I bought one new and now I can't get it to work. Fluid was coming out of the bleed screw but it wasn't under pressure and the pedal goes to the floor. What am I doing wrong?
Old Aug 14, 2017 | 01:34 AM
holmesnmanny's Avatar
Default Re: Clutch master cylinder.
thoroughly check for any leaks both around the system and behind the slave cylinder boot
Old Aug 15, 2017 | 03:55 PM
prodjay10's Avatar
Thanks. I need to invest in a bleeding tool but even under vacuum it wouldn't pull out all the air. I finally got it to work by pressing the clutch pedal a million times. I think the only difference was that the lid was on the reservoir this last time I tried it. Idk. I've never had this problem when working on brakes.
Old Aug 19, 2017 | 08:08 PM
bbarbulo's Avatar
clutch hydros aren't like brake hydros. i've had good luck leaving the bleeder open, keeping the reservoir full, and working the pedal up and down by hand. leave pedal up, close bleeder. make sure you are using a bleeding cup and cup is higher than bleeder screw but lower than CMC. i change my DOT3 fluids every 3 years. HATE seeing dirty old hydraulic fluid.
hitop
Aug 13, 2015 10:34 AM
fcjohnny
Nov 19, 2009 07:33 PM
niceprelude
33
Dec 20, 2008 04:56 AM
JoJO...
10
Sep 30, 2005 08:56 AM
bradwcampbell
Mar 26, 2002 04:11 PM
