Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Defrost issue
Old Aug 12, 2017 | 01:44 PM
Michelle Price's Avatar
Default Defrost issue
My ac works. The air blows. In the mornings, when I pull from the garage, my windows fog up. When I turn the defrost on, it blows cold air, like the ac is on. I make sure that the ac isn't on or the recycle. After I get a few miles away from home, all of a sudden the defrost starts working. Any ideas?
Old Aug 12, 2017 | 04:43 PM
toyomatt84's Avatar
Sanji
Default Re: Defrost issue
What kind of car is this?
Old Aug 12, 2017 | 04:57 PM
Oops, sorry! Civic EX.
Old Aug 12, 2017 | 07:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The A/C is automatically turned on when you use the defrost setting on the mode dial.
If it is too cold for you, adjust the temperature control dial.
See excerpt from owner's manual:
Old Aug 13, 2017 | 02:47 AM
It Wasn't Me's Avatar
Your heater blows cold air until the engine fully reaches operating temperature?
I'm stumped.
Old Aug 13, 2017 | 11:52 AM
prodjay10's Avatar
The heater gets heat from the engine coolant. When the coolant gets hot and circulates through the heater core is when you have hot air thru the vents.
Old Aug 13, 2017 | 11:58 AM
The first thing that I do, is put on the heat and defrost mode on high.
Old Aug 13, 2017 | 12:00 PM
Is there a way to upload a picture of how I have my settings?
Old Aug 13, 2017 | 04:25 PM
toyomatt84's Avatar
Sanji
That won't make the engine's coolant magically change from cold to hot. The reason your defrost is cold when you just started the car, is because it functions off of the coolant in your engine via the heater core. So, until the engine is warm, you won't get any heat inside the cabin of the vehicle.
Old Aug 21, 2017 | 08:54 AM
NDNV's Avatar
Make sure you have changed your cabin A/C filter recently.
Old Aug 23, 2017 | 01:24 AM
holmesnmanny's Avatar
It's possible to turn off the automatic ac on when defroster is selected by using this tutorial.
mirfan389
Aug 24, 2017 06:14 AM
Frizou
Aug 15, 2017 06:48 AM
Revolver123
Jun 12, 2008 03:08 PM
00b18b
Dec 14, 2001 01:55 PM
