Honda CR-V & Element 2WD & 4WD Element & CR-V
98 Crv swapped standard no Reverse lights help please!- Beginning of crvtec swap.
Old Aug 9, 2017 | 01:30 PM
526jjm's Avatar
Default 98 Crv swapped standard no Reverse lights help please!- Beginning of crvtec swap.
whats going on guys i have a 98 crv lx was auto now its standard i was wondering if anyone knew how to get reverse lights in.
Also need some help and advice on this build im working on (b20z block/ b16a2 head) i have a ton of questions and all help will be appreciated
Old Aug 9, 2017 | 06:57 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 98 Crv swapped standard no Reverse lights help please!- Beginning of crvtec swap.
What main wire harness and what engine harness are you using (automatic or manual, mix)?
Regardless, one method is to locate the Yel/Red wire that went to the connector to the A/T reverse relay (located under the driver's side dash). If you are not using the engine harness for the manual transmission, cut the Yel/Red wire at the A/T reverse relay (it comes from under-dash fuse no. 10.) and splice it to new wiring and connect it to the Grn/Blk wire at terminal no. 2 of the back-up light switch located on the manual transmission. Another new wire needs to be connected to the Grn/Blk wire at terminal no. 1 of the back-up light switch and then back into the cabin area and connected to the Grn/Blk wire at the A/T reverse relay connector. -- You will no longer need the A/T reverse relay.
Old Oct 10, 2017 | 03:30 PM
526jjm's Avatar
I have a automatic harness, thank you for that i am going to check that tomorrow. My timing belt ending up going on the block i had, so i ended up having to swap my head in faster. i ran new lines for my vtec, would you have any idea which pins the wires go to?
Old Oct 10, 2017 | 03:38 PM
526jjm's Avatar
also if there is a way to delete or relocate an iat sensor
lsvtecej6
27
May 7, 2009 07:48 PM
ShakesTheKlown
Mar 29, 2004 09:19 AM
ukkb920
Mar 15, 2004 08:09 PM
