Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Where is Radiator Fan Switch Sensor on 06 Civic?
Old Jul 31, 2017 | 04:22 PM
alextech's Avatar
5 Year Member
Default Where is Radiator Fan Switch Sensor on 06 Civic?
I searched on google and was not able to get an answer. Im guessing is right near the oil filter? The radiator fan wont come on and will just overheat, I used a jumper on the relay and the fans work when I jump it and had just replaced the thermostat thinking it was open but it wasnt. And Fuses are OK.
Old Jul 31, 2017 | 06:15 PM
alextech's Avatar
5 Year Member
Default Re: Where is Radiator Fan Switch Sensor on 06 Civic?
Actually, I just found out its just 2 sensors. Fan switch on the radiator and ECT on thermostat. Thanks to honda auto parts diagram. Tomorrow I will replace it and find out if it worked or not.
Old Oct 8, 2019 | 03:58 PM
Jdonovan56's Avatar
Did the sensor end up making your fans work when they should, which sensor was it? The one on the fan shroud? I'm having the same issue
Old Oct 21, 2019 | 07:47 PM
peppermrj's Avatar
Two ECTS. 1 by the thermostat. 1 by the bottom rad hose.
Too much air in the system will cause overheating and prevent proper fan operation.
Rebleed with the front end raised. Rad cap highest point. Fill, turn the heater to full hot, start the engine and top off as needed. Give the rad hoses a few squeezes to help things along. Honda recommends too fan cooling cycles. Took me 30 mins for the fan to kick on and the bottom rad hose to heat up. Repeat procedure.
Good luck.
Last edited by tech8; Oct 26, 2019 at 02:21 PM. Reason: Links to copyrighted material not allowed in forum.
Old Dec 26, 2021 | 09:49 PM
djr48312's Avatar
What were the part numbers? I"m told the ECT and Radiator Fan switch are two different part numbers.
Rodolfo Rivera
Honda CR-V & Element
Oct 10, 2017 05:54 PM
jacollins5
Honda Civic (2001 - 2005)
Sep 17, 2016 01:02 AM
dman81
May 28, 2014 03:20 AM
EK9JSPEC
Aug 27, 2012 09:11 PM
fast22civic22
May 31, 2007 09:34 AM
