Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2015 honda civic A/C doesn't work
Old Jul 31, 2017 | 12:12 PM
multi_2009's Avatar
Default 2015 honda civic A/C doesn't work
we have a 2015 honda civic 2D coupe. bought it at end of 2015, haven't been using the A/C much. But this summer when turned on the A/C, it didn't produce cool air anymore. Tried to refill the A/C with AC pro (didn't expect the refrigerant will be empty so quickly), it cannot be filled in. The pressure stays high.
Old Aug 1, 2017 | 03:54 AM
Townman10's Avatar
Default Re: 2015 honda civic A/C doesn't work
Could be something to do with your engine coolant? Or maybe your radiator? How are they doing? Is it just blowing out warm air?
Old Aug 1, 2017 | 12:29 PM
prodjay10's Avatar
Over filling can cause it to not cool properly. Ideally you'd recover and weigh the refrigerant to see if it had enough. If it's low you have a leak that needs to be repaired before you add more.
You then would vacuum for a half hour or so to add the proper amount of refrigerant. Mixing air with refrigerant will cause it to not cool properly.
vic_2002
Honda Civic (2001 - 2005)
Oct 17, 2013 08:40 PM
Ohmster
Jun 26, 2013 01:29 AM
rem_pss308
Jul 15, 2004 09:05 AM
integra dave
Acura TL, RL & ZDX
Jul 7, 2003 12:33 PM
