92 integra coolant leak
Old Jul 29, 2017 | 07:19 PM
Caffenative's Avatar
Default 92 integra coolant leak
hey guys 92 integra has a coolant leak which looks like it can be traced to this bit here. It won't leak when running but when the car is turned off it spews coolant. I've attached a photo
Old Sep 2, 2017 | 12:54 AM
trm4life's Avatar
Default Re: 92 integra coolant leak
It's most likely a coolant hose on the back of the intake. Your pic, is the speedometer cable, directly above that is a couple sensors that use coolant temp. One on the side below the throttle body, is the idle air control valve, it has a small hose on it for coolant. On the back of the intake is the electronic idle control, it also has a small coolant hose. The other hose it would be, is a larger diameter hose directly below the idle air control valve hose that loops downward.
kevinhughes13
Mar 23, 2014 06:21 PM
nonsense
Aug 7, 2003 07:35 PM
