Rear Disc Swap HELP
Old Jul 29, 2017 | 05:37 PM
BETaEF's Avatar
Default Rear Disc Swap HELP
Hey guys,
Since my trailing arm bushings were shot 3/4's of the way I decided to go with rear disc's since I had to pull the whole trailing arm.
So i found a swap from a 93 Del Sol on the ol' Craigslist. Complete with Ebrake lines and calipers.
I ordered new wheel bearings but when I pulled off the dust cover, the original bolts still had the factory paint marker on it.
I decided to hold off on wheel bearings and just add extended wheel lugs.
I just dropped my old rear trailing arms, and removed all bolts holding the cables into place around the gas tank.
Dont mind the rust on the rear, I plan on getting that welded and sprayed. Picked up a new bumper support that I have to clean up and refinish before attaching to bumper cover.
Now the fun part. Im a little unsure how to go about this part of the install.
Any suggestions/help would be greatly appreciated!!
Old Aug 2, 2017 | 02:34 PM
learco's Avatar
Default Re: Rear Disc Swap HELP
The clips in the red circles get removed from the bracket, then you ditch the entire part marked out in blue.
The clips are then inserted *through* the part marked in purple, and then into the OEM e-brake handle, marked in yellow.
Old Aug 3, 2017 | 09:20 PM
schueytenten's Avatar
That is just what I wanted to say, but I'm not that good with those little lines you put in. LOL, IM 50 YO
H23_del_soul
Jan 11, 2010 08:23 AM
s73
Aug 26, 2002 04:18 PM
