What are these for? (Engine bolts)
Old Jul 28, 2017 | 02:11 PM
t_can's Avatar
Default What are these for? (Engine bolts)
I'm wrapping up a full rebuild on a d16y7. I'm nearly ready to put it in the car but there's just a few things on the back of the block I can't remember. If anyone is willing to lift the skirt on theirs and take a peek, I'd really appreciate it.
Old Jul 28, 2017 | 03:41 PM
t_can's Avatar
Default Re: What are these for? (Engine bolts)
Also this one just to the left of the intake manifold.
Old Jul 29, 2017 | 05:40 AM
civic402lx's Avatar
First picture:
bolt is for securing engine harness bracket down.
​​​​​​Threaded hole is for nothing, empty.
Second picture:
For engine hoist bolt
Old Jul 29, 2017 | 09:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The threaded hole in the first pic appears to be the Knock sensor hole... I agree with civic402lx on the other two that you asked about.
Old Jul 29, 2017 | 10:52 PM
t_can's Avatar
In another thread, I read that the Y8 has a knock sensor, but the Y7 doesn't. Not sure if that's true or not. That surface on my block has an aluminum oxide coating on it, meaning it was exposed, as compared to the harness strap, which is bare aluminum.
Old Jul 30, 2017 | 09:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That is correct... no knock sensor is present on the Y7 engine, and therefore, is an OPEN threaded hole and will not be used with the stock engine/ECU combination.
Old Aug 5, 2017 | 08:50 PM
t_can's Avatar
In my first picture, what is that sensor directly above the oil filter? I put the engine in the car today, but didn't see anything on the harness for that.
Old Aug 6, 2017 | 09:22 AM
civic402lx's Avatar
Oil pressure switch
Old Aug 6, 2017 | 06:05 PM
t_can's Avatar
Originally Posted by civic402lx
Oil pressure switch
I don't see anything on the harness to plug into that. The engine ran today, but the oil pressure light didn't come on.
Am I missing something?
Old Aug 6, 2017 | 08:04 PM
civic402lx's Avatar
Check your harness. You are certain the oil light still functional?
see this
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-acura-wiring-sensor-connector-guide-3146770/
look at the engine harness. Then look at yours. Yours may be missing
Old Aug 8, 2017 | 08:19 AM
t_can's Avatar
see this
https://honda-tech.com/forums/honda-...guide-3146770/
Thanks to your link I was able to locate the connector. That was very helpful. I'll have to get in there soon and connect it and also confirm that the oil light still works.
Right now I'm more concerned with what I think might be spark knock. I'm wondering if I connected the injectors correctly, or if for some reason the distributor needs adjustment....
Old Aug 12, 2017 | 10:18 AM
t_can's Avatar
I'm guessing the noise I'm hearing is detonation. https://honda-tech.com/forums/engine...build-3304959/
In the interest of covering my bases, what is this? I don't see it included in any gasket kits, and yet mine had it. But I didn't use it.
Old Aug 12, 2017 | 11:50 AM
civic402lx's Avatar
That look like egr plate from y8. Which y7 doesnt have.
1fatcat
May 23, 2011 10:11 PM
Entaka
Nov 25, 2005 11:40 AM
lv6l
Jan 2, 2005 05:55 PM
civic_speed99
16
Dec 19, 2004 04:32 PM
smkngsr
Jan 2, 2002 08:11 PM
