D light blinking, BRAKE light and ABS light is on (both) CIVIC LX 2010
D light blinking, BRAKE light and ABS light is on (both) at my honda civic 2010. Then I did the diagnostic test and showed me "error-1". help to fix.
Edit: The civc works correctly and without problems, only those lights on and Error-1.
you may have blown the abs fuse in the engine fuse assembly, check with a multimeter, or perhaps the abs module connector is disconnected that sits at the top of the modulator
samyd25
Nov 14, 2013 02:42 PM
