Overheating Issue on '97 Civic DX
Old Jul 24, 2017 | 10:08 AM
Cozmikk's Avatar
Default Overheating Issue on '97 Civic DX
Hello. I have an 1997 Honda Civic DX and it keeps overheating. After about 30 minutes of driving, the temperature gauge begins to rise above the middle mark. I have even plugged in a scanner to the car and the temperature reading appears to line up. The car had a blown head gasket when I bought it and I have just finished replacing everything that you would replace along with fixing the blown head gasket.
- Water pump
- new timing belt
- Had the head milled to spec
- new thermostat
- new temperature sensor
- new radiator
- have bled coolant after refilling.
If you have any questions, please let me know!
Thanks!
Old Jul 24, 2017 | 07:48 PM
fragmare's Avatar
Default Re: Overheating Issue on '97 Civic DX
Do your cooling fan(s) engage at operating temp and blow in the right direction? Scale of 1-10, how SURE are you that there is no air in the system?
Old Jul 24, 2017 | 10:06 PM
Cozmikk's Avatar
I'm pretty certain that the fans are blowing in the correct direction and that they are engaging. I am at a 9 for the question about no air in the system. There should be none. I have bled it repeatedly and also held the car at about 2500rpm for 3 minutes with the cap off to bleed it even better.
Old Jul 24, 2017 | 11:45 PM
eghatch9295's Avatar
Stancetard Hate Monger
Did you bleed it on a slight incline?
Old Jul 25, 2017 | 06:43 AM
Cozmikk's Avatar
Where I live, we are at a slight incline. I also had jack stands under the front at their highest setting. Yes.
Old Jul 25, 2017 | 06:46 AM
mk378's Avatar
Park facing uphill, allow it to cool off completely, then remove the radiator cap and check if it is staying full. The radiator should be completely full to the top.
Old Jul 25, 2017 | 06:50 AM
Cozmikk's Avatar
I have done all of this already. I suspect that it is a different issue as I have bled the system many times over the last two days with no change in result.
Where I live, we are at a slight incline. I also had jack stands under the front at their highest setting while bleeding the coolant each time..
Old Jul 25, 2017 | 06:57 AM
DumpdEJ6's Avatar
I like the tuna here
When you bled the coolant, did bubbles stop appearing eventually? Is your overflow tank between the min and max lines? I replaced the head gasket in my CRX years ago, only to have it blow again a few months down the line. Turns out I didn't check the block for flatness and had a small raised area on the block that caused it to blow again.
Old Jul 25, 2017 | 07:32 AM
Cozmikk's Avatar
When I bled the coolant, the bubbles stopped appearing eventually.
Old Jul 25, 2017 | 07:56 AM
civicservice's Avatar
What temperature does the scan tool report before you shut the engine off?
I sense some doubt there. IIRC, the fan should engage around 200 F. Is that what you see?
Old Jul 25, 2017 | 07:58 AM
Cozmikk's Avatar
The temp gauge has been reading in the 185-190 range. It doesn't go above 190 unless i'm driving
I'll check when I get the chance.
JDMFerio01
Jun 20, 2013 11:27 AM
Phxazcvc
Jul 16, 2012 08:34 AM
ERIC1
22
Oct 6, 2010 09:33 AM
VTEConly
Jun 29, 2001 02:32 PM
VTEConly
Jun 29, 2001 10:40 AM
