1996 Acura Integra se – b18b1 / automatic; clean title
216k miles, 80k miles on transmission; most work has approx. 5k miles on it
Body & Interior are OK for race car but certainly not perfect…
Silver w/ Black exterior (many dings & blemishes but no rust or impact damage)
Black leather interior (decent condition; driver’s seat torn but seat covers included)
Power windows & locks; cruise control; sunroof; etc.
Air conditioning needs one line replace & recharge (was working prior)
Custom headliner
Wink mirror
LED interior lights
AEM WBO2
Shift light
Boost Gauge
Digital Voltmeter
Cupholder
6-Fuse panel on dash
Radio delete (CD player w/ remote & aux. input included
GSR style wing (OEM wing included)
Clear turn signals
Aftermarket rear lights (OEM included)
Kill Switch @ rear
Rear aluminum tow hook
Front nylon tow strap
Aluminum hood pins
Custom vented hood
Rolled front fenders
Rear wiper delete (OEM included)
HID headlight conversion
Clear Lamin-x on headlights
Yellow Lamin-x on high beams
Battery relocated to hatch in box w/ hardwired tender
4 into 1 header w/ DEI heatwrap & silicone coating
2-1/4” exhaust w/ test pipe (muffler included)
New NGK spark plugs 1 step colder (OEM NGK spark plugs included)
New distributor, cap, rotor & wires
Aluminum lightweight underdrive pulley w/ new belts
Rear mounted TD04hl-12T (Volvo s40 unit; 8psi wastegate spring)
Rebuildable spare turbo included (blown seals)
Rear electric oil pump w/ needle valve & oil cooler
K&N cone filter w/ cover
Front mount intercooler (aluminum & pvc pipes, silicone couplers, t bar clamps)
Front and rear strut bars (very nice DC sport)
Rear lower tie bar (aluminum)
Koni STR dampers
Eibach sport springs
Addco rear sway bar
New suspension mounts, bump stops & hardware all around
Window Weld filled motor mounts
Complete Energy Suspension polyurethane bushing master kit
Aluminum front lower control arm brace
Aluminum rear lower control arms
Aluminum adjustable rear upper control arms
New OEM front upper control arms
New front wheel bearings
New front ball joints
New inner & outer tie rods
Power Steering delete (OEM parts included)
New axles
Rebuilt front calipers
Stainless Steel brake lines
Hawk HPS brake pads w/ new hardware
New Rotors
7 mm aluminum wheel spacers @ front
Auxiliary transmission cooler w/ electric fan
Fuel pressure gauge
New Starter
Speedy 17x7 aluminum wheels
205/40r17 Falken Azeni rt615k tires
Full size spare tire
Locking lug nuts w/ key
Extra fluids & misc. bits included
Probably a bunch of stuff that I am forgetting…
I planned to race it for at least another season but circumstances have changed; could use more tuning & alignment tweaks but runs & drives well.
Needs and alignment, some tuning & exterior work and misc. small details.
