2000 honda accord ex
Old Jul 21, 2017 | 05:40 PM
steed_grady's Avatar
Default 2000 honda accord ex
we have changed the fuel pump,fuel filter,spark plugs,plug wires,map sensor,knock sensor,fuel pressure regulator,throttle position sensor,and the distributor. clean the egr valve and that made it worse.when i crank the car up in the beginning it choked down . now after cleaning the egr valve it want stay crank for even a minute it starts studdering and die. we check battery its fine . its my mom and she loves her car and i dont want her stuck on the side of the road again she is 72.
Old Jul 21, 2017 | 07:23 PM
holmesnmanny's Avatar
Default Re: 2000 honda accord ex
check mechanical timing to be sure it hasn't jumped a tooth
if good, then run a compression test
Old Jul 23, 2017 | 05:12 PM
what is a compression test
user 1959825
Jun 15, 2019 06:35 PM
Silly rabbit419
Mar 17, 2018 04:56 AM
JadedWhispers
Apr 25, 2014 02:51 PM
akzilla
Mar 13, 2014 12:37 PM
hondaaccordf23
Jan 3, 2012 02:52 PM
