Replacing ITR Rear LCA Bushings
So I have searched and not found anything that exactly answers my question... So I'm replacing the the Rear LCA bushings on my 2000 ITR with some bushings from Hardrace. The stock bushings pressed out easily, but my issue is getting the new Hardrace bushings pressed back in. They look to be the same size, but its so tight the press wants to bend or fold the LCA together... Is there any secret to pressing in these bushings or should I double check they are correct?
Thanks,
Thanks,
Measure your LCA I.D and the Bushing O.D with a caliper. It will most likely be a interference fit, so the LCA I.D will be smaller than the Hardrace O.D... I would guess around 0.008" smaller than the Hardrace OD. I would check with Hardrace, they shouldn't be that hard with a press.
Thanks,
Thanks,
I think this is the main reason Honda does not sell the replacement bushings for the rear LCA's. It ends up being difficult to setup the press "jig" perfectly so the stamped steel doesn't warp.
I asked about this on ITRCA about a year ago. I was given the advise to just buy new arms (either oem or hardrace) and that is what I would do if I were you. I do not know how strong the LCA's are when you put them on thier sides and try to press bushing in and out. For me it wasnt worth it to potentially bend the arms during that process.
On my CRX, one of the arms was a simple knock-out with hammer, knock in with 2lb hammer job. On the other arm, the bushing knocked out with a hammer fine but I noticed it was distorted into a cone shape. When I tried to knock the new bushing in, it wouldn't go straight no matter what. I bought a 12 ton press and managed to get the bushing started into the hole. But after about 1cm, the press reached it's limit and the safety-valve inside bypassed the fluid. I did manage to beat the bushing the rest of the way in with a 2lb brass hammer. The point is the arms are not a perfect shape and you never know if it will be tough or not.
The good news is you have nothing to loose. Sell the Hardrace and get some OEM (they are better anyways). If those don't press in, then buy new arms.
Your other option is to sand the paint off the Hardrace bushings to make it work.
Thanks Guys, I went ahead and dropped $150 on a set of Hardrace complete rear LCA... Getting out the rusted OEM bushings was going to bend the stock rear LCA.
RAB
Nov 23, 2004 09:35 AM
I have heard they dont last long though. We'll see.
