B16A Crank No Start
Old Jul 18, 2017 | 09:03 AM
Bleakened's Avatar
Icon5 B16A Crank No Start
Hello, H-T! Another round of bugs to sort through!
Vehicle: 1998 Civic Hatch w/ B16A + S4C Trans & EK9 ECU
Last night I went to leave my apartment and stalled the car like a dummy and when I went to restart it, the fuel pump wouldn't prime and my fuel gauge bottomed out and wouldn't move and I knew I had a half-tank.
Main relay is known good and did its normal 3 second check followed by a single click but couldn't hear the fuel pump prime.
So after 10 minutes of letting it sit, it started right up and the fuel gauge worked again.
I'm not even sure where to start looking. It's obviously not a fuse because it all worked again. Oh and the fuel filter is only about 1.5 years old.
Any ideas, H-T?
Old Jul 18, 2017 | 09:19 AM
mk378's Avatar
Default Re: B16A Crank No Start
Check the fuel tank plug and ground wire under the back seat. Remove the seat start the engine and shake everything around to see if you can get it to stall and/or the gauge to drop.
str8kustomz
Honda Civic (2001 - 2005)
Apr 13, 2015 01:55 AM
tjm6
20
Aug 2, 2013 02:33 PM
Pr0ject93hb
Feb 25, 2007 08:34 AM
krack
Jul 18, 2004 11:35 AM
