Honda S2000 Honda S2000
fuel damper line
Old Jul 17, 2017 | 04:55 PM
TEGMAN89's Avatar
Default fuel damper line
Hi everyone,
I wanted to see if anyone could point me towards any kind of walkthrough there may be to replace the fuel damper line on a 2000-2003 s2000. Unfortunately it looks like some mice put enough of a gash in it and cause fuel to spray out as soon as I turn the key to "ON" (causing fuel pump to prime). I believe the line I am talking about is number 3 in the attached picture.
Any help will be appreciated. I just hope I don't have to take off the whole intake manifold to replace it, but I think I may have to.
Thanks in advance!
Old Jul 25, 2017 | 09:08 PM
Quick99Si's Avatar
Default Re: fuel damper line
You don't have to remove the intake manifold. You have to get under the car to loosen the lower fasteners, and replace the two crush washers on the banjo bolt. Those washers are aluminum and OK to reuse 2-3 times with enough torque, but cheap enough to replace.
Old Aug 21, 2017 | 09:47 PM
groversunil47's Avatar
First of all , Honda S2000 is an Awesome Car and the fuel damper line is Common in Indian roads , Don't perform any manual Changes.. Its better to Take it to a Service Center and Fix it.
EK9r!der
18
Aug 23, 2012 09:57 PM
Type-Spaz
Mar 30, 2011 02:12 PM
teal91
10
Dec 29, 2008 07:46 AM
civickiller
Mar 27, 2004 06:43 PM
