Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Slow Crank / Fail Start Every 5 Startups or So (Video Inside)
Old Jul 12, 2017 | 09:21 AM
phish's Avatar
Default Slow Crank / Fail Start Every 5 Startups or So (Video Inside)
Can anyone help me diagnose this? The car fails to start once or twice a week (not consistent) only after it's been sitting overnight. I replaced the battery twice with a factory OEM Honda one so it can't be that. It eventually will start if I keep trying. Once it's started it's fine for the rest of the day and never does it again.
Old Jul 13, 2017 | 03:06 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Slow Crank / Fail Start Every 5 Startups or So (Video Inside)
Could be your starter. Those starters for the automatic civics are prone to fail. Mine started to act up where it would crank slowly or not at all. Thinking it was the battery I replaced it. But a week later the same symptom started again. I took the started out which is Pita and rebuilt it. The electronics inside of it were worn. Havent had an issue since then.
Old Jul 13, 2017 | 02:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It can also be the cable/wire between the positive post on the battery and the starter itself. Check the cable for any discoloration or corrosion... replace if necessary.
cbaber
Mar 8, 2015 07:43 AM
NightHawk92
Jan 9, 2015 08:06 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
MinimalXistance
Mar 19, 2006 10:56 AM
AVXHATCH
12
Jul 6, 2003 05:08 AM
