Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headgasket Gone Wrong
Old Jul 12, 2017 | 08:07 AM
Boststin's Avatar
Icon4 Headgasket Gone Wrong
Hey HT, I just did a head gasket job on my 01' Civic. After getting everything put on, not necessarily bolted down, I did a "Test start" with no exhaust manifold on. It ran "Fine", loud as ****, but ran, and so I turned it off and started putting everything back together.
After I attached the exhaust manifold and had everything all tightened down, I went to start it and heard a pop and smoke start coming from the intake side of the engine, After that it wouldn't start.
Anyone have ideas? Did I blow another head gasket or is it something else? Thanks!
Old Jul 12, 2017 | 11:58 AM
prodjay10's Avatar
Default Re: Headgasket Gone Wrong
Double check your work. Check all your electrical connections. Make sure all sensors are connected. If that doesn't fix it, check timing. The belt may have jumped a tooth.
Old Jul 12, 2017 | 12:08 PM
Boststin's Avatar
I checked over a lot of it, the thing that gets me is that it was running literally right before I put the exhaust manifold on and i went to start it right after I put it on and it popped and smoked a little and then would only crank, not start.
Old Jul 12, 2017 | 01:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
What tools do you have at your disposal?
If you have a bore scope you can look at things without disassembly. If not then you have to pull your intake manifold and spark plugs to inspect the intake valves and get a look at the piston tops.
Also might want to pull the valve cover, might spot a dropped valve.
Also the advise to check your mechanical timing is very good advise, if you are far enough out, you might have kissed a valve to a piston.
Boils down to what tools you have to what has to come off to inspect for these possibilities.
A leak down test can also point to these possibilities too.
Old Jul 12, 2017 | 10:05 PM
Boststin's Avatar
I do not have a bore scope, Tomorrow im going to pull it all apart and check the valves and cylinder heads.
I've got quite a collection of tools at my disposal and anything I dont have I can go out and buy.
Thanks for the help guys~!
Old Jul 13, 2017 | 12:04 PM
cssmith's Avatar
Bolting the exhaust could be a coincidence or maybe not. Have you tried unbolting it and trying to crank it again? Does it though any codes?
Old Jul 13, 2017 | 03:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Even with a bore scope it could be challenging getting down each runner to inspect the intake valves without taking the Intake Manifold off.
I would probably start by pulling the valve cover. If I didn't see anything obvious that way, then the IM would come off, followed last by the exhaust header. The last thing I would want to pull is the head itself but you usually can get a decent look at the piston tops through the spark plug hole.
You did say there was smoke coming out of the intake manifold right?
A leak down test can tell you volumes without taking anything off but the spark plugs.
Old Jul 13, 2017 | 10:16 PM
Boststin's Avatar
Okay so, I decided to start tearing it down andI guess the cam sprocket key broke and it came loose and I bent a valve. I looked at the piston, no obvious damage, it was one of the intake valves on cylinder 1. I replaced it and tightened down a new cam sprocket to spec, put it all back together the right way and it still cranks but won't start. I'm trowing a code(s) but I dont have a scanner. Picking one up tomorrow as its 11pm here now. Thanks for all the help guys/gals!
Old Jul 13, 2017 | 10:53 PM
prodjay10's Avatar
Sorry to hear it. At least you found part of the problem.
I didn't tighten the crank pulley bolt enough once which allowed the pulley to shift. Mangled the key and the crank shaft a bit. Still works though.
the code is a good place to start checking.
Old Jul 17, 2017 | 01:05 PM
Boststin's Avatar
So it looks like im getting a P0113 code, which is the "Intake Air Temperature Circuit High". As far as I know this shouldn't stop the car from running, The head gasket looked good when I pulled the head off to fix the valve, everything is timed correctly. I'm absolutely stumped.
Old Jul 18, 2017 | 05:54 AM
Boststin's Avatar
Looks like the Cam sprocket was 180 degree's off, going to get a completely different head from a junkyard and throw it on, my guess is that I didn't tighten the timing belt tensioner to spec (40 ft/lbs) and I am jumping teeth. The valves should be destroyed shouldn't they? Thanks for the help guys!
deepfriedjinx
Aug 26, 2024 01:01 AM
deepfriedjinx
12
Jul 30, 2014 06:39 AM
efyou
Jun 30, 2006 04:09 PM
mattbishop
10
Feb 4, 2006 09:11 PM
