Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power windows
Old Jul 9, 2017 | 06:37 PM
Tony T's Avatar
Default Power windows
Hello all!! New to the form as I'm new to Honda. Bought a used 01 to have as a work car. Obviously used cars comes with issues. Thankfully this one is minor. Only the driver side window rolls down. The other 3 windows won't roll down from the drivers seat OR the doors. So at first I wasn't hearing anything when I pressed the buttons. Checked the fuse for the other windows, they were blown. Swapped them out and thought nice easy fix right.. press the window button.. I heard something like maybe it wants to roll down but then the fuse blew again.. any ideas? Thanks!
Old Jul 9, 2017 | 07:44 PM
toyomatt84's Avatar
Sanji
Default Re: Power windows
Sounds like you may have a bad regulator, or possibly a damaged mechanism.
Old Jul 10, 2017 | 04:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
What specific fuse(s) is/are blowing?
There is probably a short in the circuit. Generally, a short is an accidental touching/connection of a wire to ground or to another wire; can also be due to short in a component's metal contacts.
Old Jul 11, 2017 | 11:37 AM
Tony T's Avatar
It's the 20 Amp fuse that blew. well two were blown I replaced both and only 1 blew right as I pressed the window button.. the other didn't blow and I hear a soft noise in the door panel like it might want to work..
Owen Pitchford
May 19, 2019 08:42 AM
Syke Fu
Oct 7, 2011 10:41 AM
dcdcdc
May 9, 2008 08:21 PM
NoTech
Aug 22, 2006 07:22 AM
TheShad0w
Jul 30, 2001 08:46 PM
