Honda CR-V & Element 2WD & 4WD Element & CR-V
2011 2.0i-vtec engine knock
Old Jul 6, 2017 | 10:43 AM
Jaycrv's Avatar
Default 2011 2.0i-vtec engine knock
Hi all. I have a uk spec 2011 crv 2.0i-vtec manual box, 45000 miles.
I have a knocking noise that seems to be coming from the bottom of the engine
at around 2000rpm once the engine is warm.
I took it to my mechanic who diagnosed it as a rod bearing on number 4 cylinder
was worn, he stripped the bottom of the engine and number 4 cylinder rod bearing was
marked and worn.
He replaced all 8 bearings with genuine honda bearings the same size as removed.
I got the car back and the noise is still there !?
can anyone tell me what might be the problem please ?
Thanks
Old Jul 6, 2017 | 11:29 AM
UK-Kev's Avatar
Default Re: 2011 2.0i-vtec engine knock
Did he check the main bearings
Old Jul 6, 2017 | 12:33 PM
Jaycrv's Avatar
hi KEV. As far as I know he saw the worn rod bearing and just replaced them.
Would a main bearing have the same symptoms I'm having?
cheers.
Old Jul 7, 2017 | 07:51 AM
UK-Kev's Avatar
cheers.
In a word YES
Old Jul 7, 2017 | 12:19 PM
Jaycrv's Avatar
In a word YES
does that mean engine out or can it be stripped in the car ?
Old Jul 8, 2017 | 04:51 AM
UK-Kev's Avatar
Yes you can change the main bearings with the engine still in the car by sliding the shells out – However it will all depend on the state of the crankshaft. If the crankshaft has deep score lines the crank will need a regrind and will need to be removed from the block.
Old Jul 8, 2017 | 12:56 PM
Jaycrv's Avatar
The crankshaft was inspected when the rod bearings were changed and it is fine.
It was only number 4 rod bearing that was marked but all were changed with the same
size (yellow) bearings.
Is there a way to check if the main bearings are worn ?
Thanks
Old Jul 8, 2017 | 02:22 PM
UK-Kev's Avatar
Thanks
Yeah you remove the main bearing caps
grayzz
13
Mar 24, 2016 02:35 PM
NoWorry's
May 6, 2013 06:12 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
Jared
Sep 13, 2005 01:16 PM
Dyzee
10
Apr 28, 2004 11:56 AM
