Transmission & Drivetrain Gearboxes, Differentials, Clutches
Wrong linkage? No 5th or reverse
Old Jul 5, 2017 | 07:05 AM
adam4g's Avatar
Default Wrong linkage? No 5th or reverse
Hey guys just did my first swap. 91' B18A1 into 93 EG and used a LS hydro trans. I used the linkage from the DA integra that came with the swap. After it's all said and done I cannot get the car into reverse or 5th gear. Before ripping the trans apart I just wanted to know if possibly I'm using the wrong linkage. Should I be using 94'-00' integra linkage? I've searched and searched before posting but have found answers in both directions. Just looking for a definitive answer here. Thanks!
Old Jul 5, 2017 | 07:12 AM
chuck chainz's Avatar
Default Re: Wrong linkage? No 5th or reverse
Im pretty sure you have to use a 94-01 linkage or even an EM1 linkage.
Put your car on jack stands, remove linkage, stick a screwdriver through the bitch pin hole and see if it'll go into 5th and reverse that way. If you catch those gears you know your problem is the linkage.
Old Jul 5, 2017 | 07:15 AM
adam4g's Avatar
Ok good info! I will try after work. Thanks!
Old Jul 5, 2017 | 09:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, you have to use the '94-01 Integra shift linkage. The EM1 (Civic Si '99-00) will also work.
vtechjunkie
41
Mar 7, 2010 07:47 PM
Anti-Drama Queens
Apr 8, 2006 05:27 PM
aka
Nov 18, 2005 11:32 AM
B-B-K
Jul 22, 2004 08:10 PM
