Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 CR-V Check Engine + VSA Warning Lights
Old Jul 3, 2017 | 03:46 AM
tylerzero's Avatar
Default 2005 CR-V Check Engine + VSA Warning Lights
I was in the mountains driving through some very dusty conditions. On the way back, all of a sudden the check engine light came on, followed by the VSA system and activation lights as the car started to bog and forced me to pull over.
I shut off the engine for a short time. After I started it up, the VSA lights were off but the check engine light remained on.
I stopped at a self-service car wash; once I started it again, the check engine light was no longer on.
Any ideas as to what was/is going on and whether I should be concerned? This is the first time anything like this has ever happened.
Old Jul 3, 2017 | 10:25 AM
Occidentalis's Avatar
Default Re: 2005 CR-V Check Engine + VSA Warning Lights
Existing problem with oil leakage / blowby? Check oil volume, pull the check engine code if it's still in the system. Other people might have better ideas.
Old Oct 27, 2022 | 07:21 PM
crvbro's Avatar
Pedal position sensor is bad. Very common on this gen crv. Eventually it will not drive at all, as the sensor sends a signal to the throttle body to open and close. Also, replace the vvt oil pressure switch at the same time.
cennouu
Jan 12, 2011 07:49 PM
MiMiK
Apr 2, 2005 12:20 PM
jjaeschke2
Apr 20, 2003 05:14 AM
