Ecu
I am wondering if there might be another Ecu I can use on my 96 civic dx 1.6 d16y7. Mine is not coming out of readiness for o2 and cat. Put new manifold w converter new o2's. Check for leak at intake, checked injectors. Not sure what else to check. Put different Ecu in. Was a 37820 p2e l32 and got evaporate code. Code was for fuel tank pressure sensor too high. Checking I don't have that sensor, but Ecu came out of readiness. I am having a hard time finding an Ecu for it. Have found others but not sure if they will work.
Convert to obd1 and run a chipped p06 or p28. Your car will have some potential. You can chip in launch control, or a new rev limiter and play with some things. Or if you're going b series for the ecu to work all you will need is a new chip.
Oh and you can get rid of that nasty code.
