Honda S2000 Honda S2000
Seized front lca bolts
Old Jun 29, 2017 | 06:50 AM
q071302's Avatar
Default Seized front lca bolts
Hi, i have a 2000 S2K with seized front lower control arm bolts ( both sides). What would be the best or easiest way to get them loose, as I need to adjust the lca's to fit different wheels.
I already tried spraying them in, several days, with rust desolver (rustico) and WD40. No luck.
Next phase would be to try to cut away the seized bolt from the inner part of the subframe, where the lca is inserted in the subframe.
Do you guys have other suggestions?
Old Jul 3, 2017 | 12:26 PM
JulieU's Avatar
Default Re: Seized front lca bolts
Might try heating them up with a torch.
Old Jul 4, 2017 | 01:20 AM
q071302's Avatar
That would be an option. I have a spare subframe with LCA, also with a seized bolt. I will try it first on that , before I torch the complete car down.
Atomic1
Jun 2, 2011 10:22 AM
thundernoodle
Jul 10, 2010 03:54 PM
SuperSi
56
Aug 1, 2006 07:34 AM
ZipTieGUy
Feb 27, 2006 06:08 PM
Ragezero76
18
Sep 22, 2002 04:23 AM
