help...trouble shifting gears
Old Nov 10, 2002 | 07:11 PM
streakz's Avatar
Default help...trouble shifting gears
When i shift from gear to gear, the throw isn't smooth, meaning it doesn't slide like KY jelly. That means i can't downshift as fast nor easily. I changed the transmission oil. Doesn't help...any suggestions?
Old Nov 10, 2002 | 07:38 PM
NeXTLeVeLGeN2's Avatar
Default Re: help...trouble shifting gears (streakz)
might be your sycro's
Old Nov 10, 2002 | 08:21 PM
piatl7il77's Avatar
May want to check the shift linkage. Bushing gone bad.
Old Nov 10, 2002 | 08:37 PM
integraautox's Avatar
Default Re: help...trouble shifting gears (piatl7il77)
how many miles on your car. I had the same problem a week ago then I changed my tranny oil and a day later it felt like butter again. I would suggest doing that if it hasn't been done in the last 25k miles or so. Just go get the oil for like $15 from acura and do it your self it is simple and takes about 30 min or so. good luck
Old Nov 10, 2002 | 08:42 PM
Solipsist's Avatar
That reminds me, I've got to change mine too.
Old Nov 11, 2002 | 10:49 AM
jdmb18c's Avatar
Default Re: help...trouble shifting gears (TEXASLS95)
I had the same thing happen to my trans. Shifting from 2-3rd gear and it was the syncro. The parts were not cheep. I hope it is your linkage, alot cheeper to fix but if not get it fixed asap. It gets hard on the gears after awhile. Good luck.
Old Nov 11, 2002 | 04:45 PM
streakz's Avatar
thanks..i'll take a look at that
Railroader
Mar 25, 2014 08:09 PM
dudesitsjdm
Mar 9, 2010 01:45 PM
eMpAtHy
Jan 22, 2009 10:42 AM
lostkoz
Apr 12, 2006 06:12 PM
AznInvasion
Aug 24, 2002 06:15 AM
