Transmission & Drivetrain Gearboxes, Differentials, Clutches
honda civic LX '00 honda civic LX '00 the Car wont shift into drive
Old Jun 24, 2017 | 07:52 AM
semse2's Avatar
Default honda civic LX '00 honda civic LX '00 the Car wont shift into drive
Hi have honda civic LX '00 the Car wont shift into drive. I am pushing the brake down and it wont let out of park, but I click the button on the shifter, and then let me shift also the transmission shift at high RPM, 4000 rpm,no codes and all fuses good, someone can help me please ?
Old Jun 24, 2017 | 03:02 PM
BrakeExpert's Avatar
Default Re: honda civic LX '00 honda civic LX '00 the Car wont shift into drive
Please rephrase that.
When the engine is on and you push the brake, do you hear a small click sound coming near the gearshift? There should be. Also are your brake lights on all the time?
Can you move the shifter with the key inserted into the override slot?
Old Jun 24, 2017 | 03:50 PM
semse2's Avatar
Thank you for your help,
When I push the brake with the engine on , I do not hear a small click sound coming near the gearshift .My brake lights are not on all the time, just when I push the brake , Yes I Can move the shifter with the key inserted. Now the light of the check engine is on and when I put the scanner the code that gave me is the P1106 Barometric pressure sensor, I did procedure to check the map sensor and it is good and I did the procedure to reset the Barometric pressure sensor code and the code went off but when I turn off the car and turn back on and I start to drive, the same code (P1106 )come back again , I know the Barometric pressure sensor is at the ecu but I need to know the exactly location at the ecu so I need the schematic for the ecu.
Old Jun 25, 2017 | 08:34 AM
Check the plug. The TPS and MAP sensor happen to use the same plughead, its not likely but possible they were swapped. Now if you dont hear any noise and can't shift with the engine on, sounds like the interlock solenoid is doing what's suppose to to prevent unwanted shifting. So i'd check the fuse to that solenoid, or maybe its not working.
semse2
Jun 24, 2017 07:50 AM
pinoyboy204
Honda CR-V & Element
10
May 26, 2012 02:35 PM
dlowdog
Dec 1, 2007 07:56 AM
ACCORD0000
Oct 4, 2006 07:16 PM
Havokmkr
May 13, 2003 03:24 AM
