Havin problems with my lude. plz help!
Old Nov 10, 2002 | 06:52 PM
visual's Avatar
Modified by visual at 11:06 PM 1/5/2007
Old Nov 11, 2002 | 12:51 AM
armharm's Avatar
Default Re: Havin problems with my lude. plz help! (visualvb)
cmon guys.. help my best friend out.. gude? boosted97? oh yea and we figured out the vtec problem, it was cause the car was not warmed up enough.. anyways yea whenever i punch the car (i.e.: vtec engages) the headlights start flashing and dimming and the left turn signal starts lighting up slowly and eventually the check engine light comes on.. but then when we restart the car the check engine light is gone.. so i'm thinking it has to do with the vtec.... any help is appreciated guys..TIA
Old Nov 11, 2002 | 06:22 AM
prelude1897's Avatar
What engine code are you throwing? If you can find out what code you are throwing, then you can find you problem...Did you reset your ECU after you installed the intake? Try reseting it, and if the light comes back on, then you have a problem.
Old Nov 11, 2002 | 10:46 AM
armharm's Avatar
Default Re: Havin problems with my lude. plz help! (prelude1897)
yea we're gonna check and see what code its throwing today... andthe only thing we did to reset the ecu was disconnect the negative battery terminal for about 2 hours...
Old Nov 11, 2002 | 09:56 PM
PrecisionH23a's Avatar
Default Re: Havin problems with my lude. plz help! (armharm)
It should only take 30sec to reset the ecu this way. Someone obviously bumped something out of place during the install. Did you get a check engine code yet? Look over ALL of the intake manifold vacuum lines, check the fuse box for blown fuses, and make sure that the altenator is properly connected. Thats the only things i can think of, all i can say is when you installed the intake something was tinkered with...
Old Nov 11, 2002 | 10:12 PM
Honda318dx's Avatar
Default Re: Havin problems with my lude. plz help! (GudeH23a)
I'm thinking Bad alternator...
Old Nov 11, 2002 | 10:31 PM
Default Re: Havin problems with my lude. plz help! (Honda318dx)
does an altenator throw a check engine light?
Old Nov 12, 2002 | 12:08 AM
armharm's Avatar
the thing is that we're not able to get the code since the check engine light only comes on after u engage vtec several times.... and if u turn off the car its gone.. one thing is that the pulleys were all replaced and some bearing or something was busted, which was also replaced.. now there's a whistling turbo type sound coming from where the pulleys are...
Old Nov 12, 2002 | 12:21 AM
you never provided that info to us before! Lets see here.... what bearing was it that busted? Im assuming you replaced the altenator and power steering pulley? If you guys did the altenator pulley, im willing to bet money this problem is altenator related. I had a problem with my CEL light coming on a few months ago after about 3 minutes of running, and i could never get it to throw a code, but putting in the hondata fixed that for me. when the CEL light is on, try pulling over and then trying to pull a code... its worth a try.
Old Nov 12, 2002 | 12:30 AM
armharm's Avatar
is it ok if i get the cel code while the car is running?
Old Nov 12, 2002 | 12:46 AM
i tried to throw the code when the engine was on and running, i wasnt successful. but maybe you will be, its worth a try at least. are you losing power? are you still having the electrical problems as well?
Old Nov 12, 2002 | 01:06 AM
when you say grey wire, is it from the wire harness? that right there could be your problem... try to get a picture of it and post it on here, that will help out a lot.
Old Nov 12, 2002 | 01:17 AM
do me a favor, take several pictures of your engine bay, from the wire hanging loose, your intake manifold vacuum lines, pulley/ altenator area, and other locations of the bay that you worked on.
Old Nov 12, 2002 | 09:45 AM
armharm's Avatar
shutup i'm not lazy...lol
Old Nov 12, 2002 | 10:53 AM
armharm's Avatar
arm, you know you're lazy. im lazy too. lol just get a bolt-on!!!!
yeah CEL comes on when it hits the limiter. that sucks, i wanna hit the limiter! there has to be someone else that gets a CEL when engaging vtec until cut-off.
go to hell
armharm's Avatar
and btw the headlights still flicker a little..
Old Nov 12, 2002 | 11:12 AM
armharm's Avatar
trust me... at high speeds on the freeway
Old Nov 12, 2002 | 12:47 PM
the fan coming on is normal, its just cooling your car down.
Old Nov 12, 2002 | 12:48 PM
Default Re: Havin problems with my lude. plz help! (krrrrrrzyrebel)
Your able to drive now? Crazy....ahhh..that fan right there is a result of a malfunctioning thermostat....
no
Old Nov 12, 2002 | 12:49 PM
armharm's Avatar
wtf? how'd u get it out of the garage?
armharm's Avatar
no
garen.. what are you smoking? the fan just comes on to cool the car down... its normal... i'm disappointed in u..
Old Nov 12, 2002 | 02:17 PM
armharm's Avatar
oh thank god... ok ill have the pics of the engine bay up tonite. thx again gude
armen took it out. had to get it to insurance company so they good take pics.
[Modified by visualvb, 3:12 PM 11/12/2002]
oh ok... did he say it was fast?
Old Nov 12, 2002 | 05:10 PM
armharm's Avatar
it's all good garen, armharm is just getting u back for his ignorance of trying to hit vtec with only 1 bar on the temp scale and also for his bolt ons! lol dont worry bout it dood, i know u know cars.
WHY WONT IT EVER STOP!!!!
Old Nov 12, 2002 | 05:12 PM
armharm's Avatar
and take the car to the track..but I haven't heard too many great things about armens driving skills......
yea... listen to garen... bring the car to the track on friday (garen ur coming too btw) and armen isnt a bad driver.. he's just a little happy with the gas pedal...
Old Nov 12, 2002 | 05:16 PM
armharm's Avatar
ey..about the thermostat thingy..I only said that from what I remembered when you first got the car...guess i was wrong, sorry for making a mistake.
atleast u kno what a bolt-on is... god i hate that thread..
[Modified by armharm, 6:17 PM 11/12/2002]
