1993 Del Sol Gremlin
so it seems I've stumped the mechanic, this is my first car and I don't have too much know how about cars, just the basics. We had a few issues fixed like sensors and getting the a spark back to the engine and fixed the rpm's from fluctuating while in idle and so on. The problem now is it's inability to start when it's not warmed up. He says it could be a bad negative connection or a fuel injector but I don't have a firm understanding of the situation since I haven't had my hands on it.
Over the past 2 weeks I've replaced:
-the battery
-distributor
-spark plugs
-spark plug wires
-main relay
-tps sensor
-coolant sensor
if you could lend any help or similar expierences it would be much appreciated
-the battery
-distributor
-spark plugs
-spark plug wires
-main relay
-tps sensor
-coolant sensor
[QUOTE=eghatch9295;51326673]if the car wont start unless its been warmed up, how does it ever start at all?[/QUOTE
trying to to get the engine to turn over constantly when it's warm out
-the battery
-distributor
-spark plugs
-spark plug wires
-main relay
-tps sensor
-coolant sensor
-the battery
-distributor
-spark plugs
-spark plug wires
-main relay
-tps sensor
-coolant sensor
Be detailed about the problem.
where did you get the tps and distributor?
plenty of dodgy parts out there.
learn how to test both:
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
https://honda-tech.com/forums/honda-...hread-2830131/
Bad ground connection? "Warm out" means usually something expands and makes a connection that otherwise is contracted when it's "cold out". Clean off your ground connections.
Have you resoldered the main relay?
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
JesusGLS
Jan 13, 2013 04:59 AM
sym32one
Jan 7, 2012 05:15 PM
cachase1
Feb 26, 2008 08:21 AM
