advanced timing until knock (VITARA SETUP)
Old Jun 23, 2017 | 11:06 AM
Roy Leyva's Avatar
Default advanced timing until knock (VITARA SETUP)
Hi
I was thinking if i should be advancing the timing as much as possible right before it knocks in non boost portion to compensate the power for the low compression 7.5cr (later do the same for boost portion). And another question are if there´s is some kind of limit in timing advance at wot, or for example i can go up as high as 35 degrees or more in column 10 if still no pinging.
(NOTE: Map with advanced timing only for ilustrative purposes)
Thanks
Old Jun 24, 2017 | 10:59 AM
1HGEJ2's Avatar
Default Re: advanced timing until knock (VITARA SETUP)
i would make 30.00 on column 10. 35 is al lil to much. which fuel?
Old Jun 24, 2017 | 10:38 PM
motoxxxman's Avatar
when it starts to knock, its several degrees too much. not just a hair too much. usually when it knocks its anything from 3-7 degrees too much timing.
Old Jun 26, 2017 | 07:26 AM
Roy Leyva's Avatar
Using 91 pump, I usually tune 30 for degrees at wot for stock compression and 26-28 for high compression setup, but my car have only 130psi piston compression and make a test going to 35 degrees at wot and still don´t have knock. (Note: im using a knock link meter, so i can detect any knock accurately)
The map looks like this with still no knock
codenamezero
Sep 11, 2011 09:55 AM
SOHC_MShue
Sep 17, 2006 09:47 PM
spoolingb20
Apr 26, 2006 10:46 AM
sleeperb16a
Nov 19, 2004 07:32 AM
wzcb08
May 19, 2003 07:47 PM
