Euro R swap w/LSD into 97 SH
Been a member on this site since 03' and now i'm finally seeking some resourceful advice.
My 97 SH finally went out at 283k miles. I decided to go with a H22a Euro R with LSD tranny.
From my understanding and research, I can keep everything the way I received the swap without much modification.
This is what my friend is doing on my swap:
EGR blocked off
JDM distributor and modify internals
Swapping IACV valve from USDM to JDM with an adapter from Rosko Racing.
Using AEM fuel rail with adapter from Rosko
Running p28 with Hondata
Changing all seals and gaskets, water pump, timing belt etc.
I am trying to make sure this goes as smoothly as possible. Any advice from anyone else that has done this swap?
Thanks in advance everyone!
EGR blocked off
ATTS doesn't work with an OBD-1 ECU conversion with or without Hondata. The car will drive... but no LSD anymore. So, you will get a well tuned engine with the extra weight of the ATTS system and a base "one tire fire" transmission.
LSD and ATTS are completely different.
I will post pictures once completed. We are a month in a week in and almost complete. It has taken longer than I expected, but things always come up and never go smoothly. I'm hoping by this week.
