ignition coil replacement
Old Jun 18, 2017 | 05:44 PM
Jeremy Dunn's Avatar
Default ignition coil replacement
I would like to know how do i get this ignition coil out of there if its even possible.
Old Jun 18, 2017 | 07:43 PM
oneheadlight's Avatar
Default Re: ignition coil replacement
yes it's possible. you can see one of the hex head/bolts to the right of the ignition coil holding it in place. See that rubber o-ring that has two D-shaped plugs that goes all the way around the distributor housing? Pull that off then you'll have the room where you can use a socket or philips screwdriver to remove the long bolts holding the ignition coil in its tray. I'd probably use a socket if it will fit, less chance of rounding things off if it's stuck in there.
Oh and take needle nose pliers and gently remove the spade connectors on the right side of the coil. And remove one of the wires that is in the wire holder along the back edge of the coil.
You must have an HX civic, because that's a picture of the Hitachi distributor.
Old Jun 20, 2017 | 11:49 AM
Thank you. I got it replaced. I haven't tested it yet since my valve cover bolt got overtorqued
Hybrid Invasion
Nov 25, 2007 11:50 PM
boostincoupe
Sep 2, 2006 08:54 AM
civicmp
Jul 19, 2004 06:28 PM
duckming
Jun 3, 2003 12:31 PM
