93 del sol 98 b18c swap
1998 b18c swaping in a 93 del sol which t bracket do i need to do the swap plz be specific on year had the b18 in a 98 civic ex i have a b16 si t bracket now tried it and its to short. (T bracket meaning rear engine mount bracket ) plz help thank you
The factory Del Sol part number is 50827-SR3-N12 and is still available from your local Honda Parts Dealer.
I can verify it is the 94 integra bracket, this link helped a lot ----> https://honda-tech.com/forums/hybrid...-swap-2976738/
Del Sols are basically EG Civics ~ DC/DB Integras. The engine/transmission components are the same with the exception of the shift linkage. You will need one from a DOHC VTEC B16 Del Sol. The D series and Integra B series one WILL NOT WORK.
If you plan to retain the factory AC compressor, use a compressor bracket from either a '96-01 Honda CRV or Del Sol DOHC VTEC. The ones from an Integra will not allow all the bolts to line up (4 mounting bolts of the compressor, not the bracket bolts)
