I cant seem to find the right spark plug coils for my H23A
Old Jun 16, 2017 | 01:37 AM
H23LUDEY's Avatar
Default I cant seem to find the right spark plug coils for my H23A
Hey guys, i have a 01 prelude with h23a swap. But i cant seem to find the right sparkplug wires to fit. All the wires i get are either too short and dont reach the spark plug or to thick and dont fit in the hole. The dizzy is internal coil so its only 4 plugs. Some forums said to i probally need integra or civic coils but that didnt work either. So now im stuck. 1 of the plugs going into the dizzy is basically snapped in half due to corosion. So sometimes it misfires and sounds something like a backfire in idle. Its just popping while in idle. Not sure if the popping is related to the coil or gas/air ratio. The car pushes nd the engine seems pretty healthy just the coil is annoying the **** outta me. Thanks
Old Jun 16, 2017 | 03:38 AM
TimiK's Avatar
Default Re: I cant seem to find the right spark plug coils for my H23A
h23 vtec?
should be same than in h22?
Old Jun 16, 2017 | 06:11 AM
snobordboy's Avatar
Moderator
Yup, get plug wires for an H22.
Old Jun 16, 2017 | 11:52 AM
H23LUDEY's Avatar
Yup its vtech. Nd thanks guys ill try that again. Hopefully they reach. Cause the h22 plugs have an extra coil. So i tried it buh they wouldnt fit properly. Any advise on what kinda coils i should grab? Ngk? Or from honda?
Old Jun 16, 2017 | 12:06 PM
H23LUDEY's Avatar
I just wanted to add that i only get 320km on a full tank. Which im pretty sure isnt normal lol it has h23a Vtech. Running obd1.
Old Jun 16, 2017 | 12:41 PM
TimiK's Avatar
Wrong ecu/map?
Did you rebuild your engine when you changed it?
Old Jun 17, 2017 | 12:35 AM
holmesnmanny's Avatar
You don't use coils you use wires.
Old Jun 17, 2017 | 03:44 PM
H23LUDEY's Avatar
Yes i know you dont use coils. But the actual coil part of the plug is either too short or too thick 2 fit into the valve cover. I will try the H22 plugs again and see how it works out
Old Jun 18, 2017 | 05:55 PM
you keep using the plural form of the words "coil" and "wire" so it looks weird
there is only one ignition coil and ignition coil wire for the car
Old Jun 30, 2017 | 07:14 PM
gilbert2o9's Avatar
Icon5 Re: I cant seem to find the right spark plug coils for my H23A
Hello there fellow lude dudes. i just bought a 97 prelude base model. i have been having a few problems with it including overheating, and i believe my transmission is either slipping or the clutch is going out. the car is in decent shape for being 20 years old but there are definitely some modifcations that have to be done to it. NOW WHAT I AM WORKING ON TODAY IS MY FOG LIGHTS. my fog light switch in the car wont even stay clicked in. when i hold it in the light on the button lights up but it wont stay pressed in. also, the fog lights wont come on what so ever. im not sure if there is a short in the circuit or if the bulbs are bad,. i am assuming the bulbs are out so i went and bought the replica bulbs(h3) and im not sure how to install them.. can anyone give me some pointers?? thanks !
gmcuajo1
Dec 28, 2016 01:18 PM
Justef Datshiet
Jan 14, 2013 03:08 PM
5speeder
Nov 7, 2011 04:07 PM
crfr230
Mar 11, 2007 05:48 PM
ASpec818
11
Jan 2, 2005 05:29 PM
