Huge $20k+ part out first come first serve
Old Jun 14, 2017 | 05:51 PM
W!d3b0dYr3X's Avatar
Default Huge $20k+ part out first come first serve
Huge part out over 20k in parts. All parts are brand new never used unless noted. Prices do not include shipping or pp fees which YOU the buyer will be responsible for. If price is not what you have in mind please feel free to pm and discuss it with me. I will absolutely not tolerate low balling offers as the parts are priced pretty fairly and you will be blocked period as I do not have time for it. I'm located in middle TN and willing to meet to avoid shipping when possible (meaning on my time when I'm free).
In short the engine is still together so allow time for me to remove parts that have been paid for. It is a 2.2l b series stroker motor. I'll sell the entire engine (add up costs below and make reasonable offer), part it out as long block, head, turbo kit, and trans for better deals, or part it out piece by piece. 98% of parts will come with original receipts. On to the goods
Dart tall deck b20 226mm 85mm bore block. All machine work has been done necessary by Shackletts in Nashville TN- $2400.00
Pr4 non vtec head portflow p&p new bronze guides chambers matched to bore of block-$1800
Cable trans-$600.00
Extra 85mm cosmetic Mls hg-Sold
Vibrant secondary t belt tensioner-$95.00
Custom cp pistons 9.0:1 3.327 bore diameter 1.453 compression height- $575.00
Fic high impedance 1650cc injectors-$750.00
Crower titanium valve locks/keepers for b series vtec head- Sold
Ferrea valve seal set int and exh for vtec head-$20.00
Toga high volume oil pump-$175.00
Moroso street baffled oil pan-$140.00
Fluidyne half size radiator-$275.00
Oem tensioner $ spring-$75.00
BC cam gears-$210.00
Mugen thermostat:$90.00
BC lightweight crank 95mm stroke-$1500.00
Fluidampr crank pulley-$340.00
Borla 5' length 3"diameter SS exhaust tubing 4 pieces- $200.00 for all or $75.00 a piece
Arp flywheel bolts-Sold
Vibrant SS 3" flex coupler-$40.00
Skunk 2 pro series intake manifold- $200.00
Autometer carbon fiber series pyrometer-$180.00
Tial 44mm mvr wg silver- $320.00
BC pro +rods p/n b93723b (these are longer rods for better r/s ratio)- $800.00
Oem 19t water pump-$90.00
Aem fuel rail silver-Sold
Aem silver fpr-$110.00
Gates t-294 timing belt for dart tall deck build (Ford Focus timing belt)-$25.00
Gates idler pulley-$30.00
Msd sport compact ignition box-$290.00
Moroso clear distributor cap-$35.00
Moroso race oil pump pickup- $75.00
Pte6776h turbo polished compressor housing 4" compressor inlet 3" outlet 3" v band t3 housing journal bearing .83a/r- $900.00
Full race pro exhaust manifold-$875.00
Hayame polished fuel filter housing with B&M fuel pressure gauge-Sold
Vibrant aluminum piping 3" diameter 18"length for ic piping all straight pieces 5 in total- $80 for all or $20 a piece
Innovative performance intercooler( came off of my evo 8)-$300.00
Synapse bov-$210.00
Act extreme clutch, pressure plate and lightweight flywheel- HD pressure plate Sold 6puck spung race disc Sold streetlight flywheel $150.00 WILL WORK DEAL IF SOLD TOGETHER
Greddy b series non vtec t belt (blue)-$110.00
Hondata S300v1 for p28 with 4bar map, cable and all accessories and boost by gear -sold
Full blown double pumper-$250.00
Walbro 255-$70.00
Hayden automotive radiator fan-$40.00
Cheap but large obx intercooler-$100.00
Ksport coilovers-$700.00
Oem ls starter-$50.00
Chrome ls valvecover-$175.00
Custom painted ls valvecover with drilled holes for catch can (needs to have fittings welded in)-$75.00
Msd 8.5mm spark plug wires-$70.00
BC stg2 turbo cams-$380.00
BC dual valve springs and titanium retainers-$380.00
Arp head studs torqued once on assembly no heat cycles on them as engine was never ran-$120.00
Samco blue radiator hoses-$65.00
BC .5mm oversized valves-$290.00
Oem alternator-$80.00
Hasport billet mounts driver and trans-$180.00
Polished/chrome alternator bracket-$45.00
Misc nitrous bottles 10lb,leads, lines, solenoids, purge valves, intercooler sprayed bars etc- message what you need/looking for for prices
Unknown brand of crank pulley polished not sure if it's underdrive but eliminates power steering-$50.00
Charge pipe cold side flanged for greddy bov 2 1/4" or 2.5" (can't remember exact size with lemon shaped flange)-$75.00
I'm sure I'm forgetting a few things and I'll ad to the list as they come up. Comment if you have sent me a message so I can check my inbox. All parts will ship with tracking info provided. Will provide pics upon request. Text for fastest response low ballers will be ignored and no trades period. 615-670-5165
Old Jun 14, 2017 | 06:15 PM
shmooly's Avatar
Default Re: Huge $20k+ part out first come first serve
do you have a complete nitrous setup there, or not at all?
Old Jun 14, 2017 | 06:18 PM
Pretty sure I have enough to make a complete one minus different sized jets.
Old Jun 14, 2017 | 08:47 PM
Valve locks are sold. Bump all prices are obo keep that in mind!
Old Jun 15, 2017 | 05:49 AM
KCRX's Avatar
Have any info or history on cable trans?
Old Jun 15, 2017 | 08:37 AM
Trans had roughly 60k miles on it from a rear end collision car I believe and I put about 15k miles on it when I purchased the car.
All pms replied.
Old Jun 16, 2017 | 05:14 AM
Morning bump all pm's replied. If your interested in something let's work a deal!
Old Jun 16, 2017 | 08:38 AM
Hondata is sold. There was lots of interests in that item guys, as title states it's first come first serve meaning first one who makes a deal and both parties agree to it. I will not mark items as pending or push off a potential sale for someone wanting shipping quotes.the only way I'll mark an item pending is if the buyer sends a deposit to hold said item.
Old Jun 17, 2017 | 08:22 AM
Bump. Let's make a deal.
Old Jun 18, 2017 | 08:48 AM
Everything is obo which means throw me an offer. Can't be scared to ask, Sunday funday bump. Going to the post office tomorrow to ship some items out nows a good time to work a deal!
Old Jun 19, 2017 | 02:27 PM
bump
Old Jun 21, 2017 | 02:06 PM
Bump
Old Jun 22, 2017 | 08:32 AM
Bump
Old Jun 26, 2017 | 02:42 PM
Bump
Old Jun 28, 2017 | 07:10 AM
Bump. All pms replied.
Old Jun 30, 2017 | 01:08 PM
Bump
Old Jul 20, 2017 | 09:39 PM
bump
Old Aug 24, 2017 | 01:36 PM
TTT bump
Old Aug 24, 2017 | 04:32 PM
DA9tothewheel's Avatar
Not trying to thread jack or anything I just read your post about Shacklett and being from TN I'm curious wether or not they do good work with Hondas. GLWS. btw
Old Aug 24, 2017 | 04:48 PM
Billybobby's Avatar
Can I get info on the injectors
Old Aug 24, 2017 | 08:39 PM
lopaka07's Avatar
Pm'd
Old Sep 1, 2017 | 12:45 PM
Bump
Old Sep 10, 2017 | 06:17 PM
Bump all pms replied
Old Sep 11, 2017 | 04:54 AM
nstyd15b7's Avatar
pmd..
