Camber plates on an 88 crx?
I have an 88 crx with stock suspension geometry, just with some camber kits (adjustable uca's) and ebay coils. Since I'm due for an upgrade on both anyway, someone was telling me that I'd be better off getting cheap, non-adjustable upper control arms and a camber plate setup like this: https://www.octanemotorsports.com/19...-p-148059.html .
This doesn't make sense to me. First of all, is the crx considered a double wishbone setup in front? The LCA is a single beam with a radius bar, not actually wishbone shaped, but it seems to generally work like one.
All the setups I've seen with camber plates are a macphearson setup where the strut bolts directly to the hub at two points (no UCA). In this setup, it makes sense how a camber plate could adjust the camber.
However, with an upper and lower control arm like I have, with the strut attaching with a fork to the LCA, it seems like changing the angle of the spring wouldn't actually effect the camber of the wheel, at least not independently of ride height.
Am I misinformed? What am I missing here?
the website is showing a photo of a kit for a different vehicle, google says a lexus.
you can tell the kit product number is different than the photo file name.
and no, there is no camber plate for a CRX or any honda from 88-2000. it is considered a double wishbone suspension and not mcpherson strut. its a shame honda no longer makes cars with superior suspension anymore...
Honda's design is considered a double wishbone style.
Style being the keyword since they did not develope the double wishbone setup as found in Indy f1 cars.
By any technical definition, an EF has a double wish bone suspension as defined by having both two upper and lower three point control arms (don't ignore the radius rod as part of the lower control arm) and having a short and long arm advantage of camber and caster control of the knuckle that is independent of the shock .
Double wishbone is not exclusive to "F1" cars, and it is obvious a crx is a FWD passenger automobile. There's no "style" or fake double wish bone going on. And it's much better performance than McPherson struts. Shoichiro Honda is rolling in his grave at the abomination of vehicles Honda has been putting out since 2000, including the stupid Civic type R with a kludged dual axis front suspension .
JSA
68
Apr 21, 2011 06:51 AM
..::91TEG-G2::..
May 23, 2004 01:53 PM
RineRacing
May 8, 2002 05:03 AM
