Check engine light on ecu light not working/flashing
Old Jun 12, 2017 | 09:58 AM
Mesm23's Avatar
Default Check engine light on ecu light not working/flashing
Hello new to the forums, tried searching but still haven't had any luck. I have a 89 civic si that cranks but doesn't start. The check engine light is on but doesn't go away and the ecu led light is not working or flashing at all. Replaced the main relay cause pump wasn't priming and still doesnt will work when jumping the wires. Also replace tps cause its wasnt getting voltage. Just wondering if there's any other way to check for codes or to check if ecu is working. Hoping its not a bad ecu.
Old Jun 13, 2017 | 09:11 AM
Mesm23's Avatar
Default Re: Check engine light on ecu light not working/flashing
Found issue and it was a bad ecu.
rudyndrew
Jan 5, 2011 05:32 PM
cuseikan
Aug 18, 2008 01:26 PM
1320king
Jul 22, 2007 12:32 PM
Project_EK
Aug 13, 2005 04:08 PM
Wayne64SS
Jun 26, 2003 10:01 PM
