B16A6 Idle
This started a few days ago when starting the car it will idle really low as if it wants to switch off....It does this for about 5 seconds then raises back to normal temperature as it should be...some help pls?
If it's specifically an idle issue does it happen at while engine is cold, at operating temp, or both?
Any CEL's?
Sorry for responding so late just logged onto the site now. I should be more active on here....any way I have managed to nail the problem. To anser ur question is happened with both. My head gasket was leaking coolant so since re torqing the head it solved the problem so far. The head gasket was changed recently I don't understand was the head under torqued?
