No start
Old Jun 6, 2017 | 05:39 AM
heathen74's Avatar
Default No start
We got a 91 civic used, ran good once we put some clean gas in it, two days later it won't turn over. all the cluster light come on but it doesn't even try to turn over. pulled the starter, tested bad, got a new one put it in same result.
Old Jun 6, 2017 | 07:24 AM
4drEF's Avatar
Keyboard Humorist
Default Re: No start
When you turn the key to 'ON' can you hear the fuel pump whir for a couple seconds?
Old Jun 9, 2017 | 12:52 PM
heathen74's Avatar
It's getting gas, just no crank. Pushed it with the quad and popped the clutch yesterday and ran it for a while. Found out that the replacement starter was bad had the newest one tested before we left the store but still nothing. Going to test all fuses again tonight and see if maybe we missed one.
Old Jun 25, 2017 | 05:48 PM
heathen74's Avatar
Neutral safety switch. Now to get that bad boy working again. If you push the switch in she starts right up. Any ideas on an easy fix. Hard as hell to get to.
Old Jun 25, 2017 | 06:15 PM
EFvtec Yo!'s Avatar
So the Clutch Start Switch? Odds are the rubber bumper that presses it in when you mash the clutch in has crumbled. Sounds like you just need to put a new rubber bumper in. Go to your local parts store and grab Dorman part# 45393. Its a bumper assortment and one of the ones in there work perfect.
Old Jun 26, 2017 | 12:21 PM
rice a roni's Avatar
You could always jump the clutch safety switch.
Old Jun 28, 2017 | 11:11 AM
jmansour's Avatar
This, if you are on a super budget and dont want to mess with anything.
Pretty sure pushing the clutch is common sense for anyone driving a manual anyways... switch seems redundant.
Old Jun 28, 2017 | 01:43 PM
heathen74's Avatar
Yeah we knew that was the problem but you giving me that part number was awesome. $4.99 and it's starting again.
magicmyst98
14
Sep 2, 2013 12:06 PM
viera
Sep 18, 2011 08:02 PM
skata89
Oct 19, 2006 04:39 PM
03K24A4EX
May 26, 2006 04:47 AM
DrewQ1
May 4, 2004 09:14 PM
